Archived from groups: microsoft.public.windowsxp.perform_maintain (
More info?)
OK if someone else writes that it should take off and circle around the
case...do you believe it?
Richard is correct!
For a Desktop or Tower Case, The Power Supply Cooling Fan should remain on
at all times when the system is running.
A secondary cooling fan may have supplementary 'software' control that
cycles it on and off based upon some thermostat inside the case.
A CPU cooling fan will run all the time.
For Laptops, the cooling fan [only one] may cycle on and off.
"tower fan keeps runing" wrote:
> well that didnt help me, some one told me that it runs when its to hot to
> cool things off, but it shouldnt run all the time
> "Richard Urban" wrote:
> > Bad connection. Bad fan. It should normally run all the time.
> > Regards,
> > Richard Urban
> > aka Crusty (-: Old B@stard
> > If you knew as much as you thought you know,
> > You would realize that you don't know what you thought you knew!
> > "tower fan keeps runing" <tower fan keeps runing@discussions.microsoft.com>
> > wrote in message news:3BE3D234-E2E5-4DE9-AB0B-CF174479E072@microsoft.com...
> > > my tower fan comes on like every 2 min., why is this happeneing, i'm lost,
> > > please help me
