Approximate Purchase Date: Parts are in the mail
Budget Range: ~1500
System Usage from Most to Least Important: Gaming(SC2 primarily), surfing the web
Parts Not Required: Everything
Country of Origin: Canada
Parts Preferences: Intel Gaming Machine
Overclocking: Yes
SLI or Crossfire: Maybe
Monitor Resolution: 1920x1200
Additional Comments: Hi all. I have been gaming on my old pre built HP computer which I bought back in 2006 or 2007. I have never built my own computer before but I have been researching my parts over the past week and here is what I picked out. I bought everything locally except the motherboard, SSD and heatsink. I'm kind of worried my video card is not powerful enough. I bought it locally so returning it will be no problem.
I'm extremely excited! I think I might even go as far sleeving all the cables.
Motherboard ASRock P67 EXTREME4 GEN3 LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
CPU Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) 4 x 256KB L2 Cache 6MB L3 Cache LGA 1155 95W Quad-Core Desktop Processor
Heatsink ZALMAN CNPS11X Extreme V-Shaped Dual Heatpipe Design w/120mm Long Life Bearing CPU Cooler Compatible with Intel Sandy Bridge
Memory CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory
GPU ASUS EAH6870 DC/2DI2S/1GD5 Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
SSD Crucial M4 CT128M4SSD2 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
*I literally only play SC2 and web browse. For now all I need is this. I may add a regular ol' 1TB HD in the future if I need to.
Optical Drive SAMSUNG CD/DVD Burner
PSU CORSAIR Professional Series Gold AX750 (CMPSU-750AX) 750W ATX12V v2.31 / EPS12V v2.92 80 PLUS GOLD Certified Modular Active PFC Power Supply
Case Corsair Obsidian Series 650D (CC650DW-1) Black Steel structure with black brushed aluminum faceplate ATX Mid Tower Computer Case
I left out all the aftermarket fans and stuff cuz they are irrelevant.
Budget Range: ~1500
Overclocking: Yes
