Hello, I was hoping that someone would be able to help me. Like the thread header says, this is my first homebuilt PC and I need help and/or suggestions.
This is my background:
I am primarily going to use this computer to watch online movies, play video games such as Starcraft 2, Diablo 3, WoW and do basic office work. I would also like to try out more intensive games like Battlefield 3 without any issues (even if i have to put it at its lowest settings, idc). But for the most part I will be playing mostly the games that i mentioned first. I would like this computer to last me at least 5 years when I decide to upgrade all over again. Then I would use this computer as a home entertainment computer and put it in my living room.
These are the components that I picked out:
NZXT Phantom Crafted Series ATX Full Tower Steel Chassis, Black
Microsoft Windows 8 OEM 64-Bit
Asus AMD Radeon HD 7770 1GB GDDR5 PCI Express 3.0 Graphics Card
Asus SABERTOOTH 990FX R2.0 Motherboard
AMD FX-8350 4 GHz Processor
Western Digital WD Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
SanDisk SSD 128 GB Internal SSD Serial ATA-600 2.5
ASUS BW 12B1ST - BD-RE drive - Serial ATA
Can you guys let me know If all this is compatible and I am confused as to what kind of powersupply I should get, Wattage and brand? and if there is anything that i am overlooking.
Thanks so much
Thanks so much
