So, I've decided it's time to get a new PC, and figured I'd learn how to do it myself this time around. 😀 I still have a ~5 year old Pentium 4 system I'm happy with, so I'm not really concerned about cutting-edge performance. I'm on a fairly tight budget, and trying to stay at about $500-600 if possible (less would be even better!). My biggest concern at this point is getting a nice, stable platform that I can potentially upgrade over the next couple of years (faster quad core, better video, etc...), and just saving as much as I can up-front so I'm able to get a working system as soon as possible.
At this point, I have my eye on a 775 socket board, reasonable dual-core, and a (hopefully) decent video card. The system will primarily be used for gaming. A few I play are: Supreme Commander, World of Warcraft, Soulstorm, among others. Again, I've been playing most of these on a fairly old system and have been content with their performance. I can wait to get around to the good parts down the road. 😀
Anyways, before I settle on a build, I would like to make sure the parts I've so far selected are at the very least going to be compatible. Still not certain what aspects of a component I need to check to ensure they'll work properly both with a given Motherboard, and the rest of the system's parts. Any adjustments, tips, or recommendations would be appreciated!
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128359
GIGABYTE GA-EP45-UD3R LGA 775 Intel P45 ATX Intel Motherboard
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115206
Intel Core 2 Duo E7400 Wolfdale 2.8GHz LGA 775 65W Dual-Core Processor Model BX80571E7400
Video: http://www.newegg.com/Product/Product.aspx?Item=N82E16814102719
SAPPHIRE 100225L Radeon HD 3870 512MB 256-bit GDDR4 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820161042
WINTEC AMPX 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model 3AXT8500C5-2048K
HDD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136075
Western Digital Caviar SE WD1600AAJS 160GB 7200 RPM SATA 3.0Gb/s Hard Drive
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811133069
Thermaltake Strike Mx VI6001BNS Black SECC Steel ATX Mid Tower Computer Case
Disk Drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16827136149
LG 20X DVD±R DVD Burner w/ SecurDisc Tech Black SATA Model GH20NS15
Power: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139008
CORSAIR CMPSU-400CX 400W ATX12V V2.2 80 PLUS Certified Compatible with Core i7 Power Supply
Think I got all of the correct links in there...
Oh, one last note... The only Windows disk I have at the moment is a copy of XP 64-bit. Would it be too difficult to get the system running with that, or are drivers and such hard to find? Thanks in advance for any help!
**Descriptions Added**
