I bought it from a random guyThe 760 twin frozr should have both an 8 and a 6 pin power connector.
If it doesn't then its not a 760!
More likely a 750/750ti.
Where did you buy it from??
Then random guy scammed you. 760s are 170W CPUs, so they all have power connectors.I bought it from a random guy
ahh well, is there a way i can install this 750ti or 750 cause i dont see any power connector. if the gpu does not need any power connector?Then random guy scammed you. 760s are 170W CPUs, so they all have power connectors.
You can install it and see what happens. Who knows that this GPU is. There are a lot of flowers in the fake GPU garden.ahh well, is there a way i can install this 750ti or 750 cause i dont see any power connector. if the gpu does not need any power connector?
ok tks. The thing works is a gtx 750, it didnt the graphic didnt need any pin power connectors. Tks for the help everyoneYou can install it and see what happens. Who knows that this GPU is. There are a lot of flowers in the fake GPU garden.
If you don't mind me asking, how much did you pay for it? I hope you did not overpay for it. Was the guy you bought it from actually advertised it to be a 760?ok tks. The thing works is a gtx 750, it didnt the graphic didnt need any pin power connectors. Tks for the help everyone
