My gpu makes a loud fan noise and then i get a black screen
zurianmartin
Commendable
Sep 22, 2017
While i am playing a game and after minimum 1 min into it my gpu fan makes a loud noise and then i get a black screen. It doesnt restart it stays at the black screen with the gpu fan making a loud noise as if it was at 100%. I didnt get this problem for the past 1 year i was using till recently when i started bitcoin mining.
Specs;
- Gtx 550 TI
- i3 550
- Windows 10
- Idk 220W PSU
220W PSU. GTX 550Ti. That's an old build...
Upgrade your PSU...
Despite the extra frequency and enhanced back-end, the GTX 550 Ti 1GB requires just a single 6-pin PCI-E power cable, and has suitably diminutive power requirements. Nvidia recommends a 400W PSU, with a maximum stated TDP of 116W.
Intel Core i3 550 has a maximum stated TDP of 75W. If you have a 220W PSU, upgrade it ASAP as it's definitely not enough to supply the power, to atleast a 400W PSU.
Upgrade your PSU...
Okayy thanks for the reply
Well i hope not ahhahaha
