I have a MSI Gaming X GTX 1070 and I have recently attempted to overclock it and am running into some weird Thermal Throttling issues. I have my core clock overclocked to 2050mhz and it stays at that speed no problem until it reaches 58c. Once the temperature reaches anything above 58c the core clock will drop little by little each degree the temperature rises. The Coreclock will even go below 2000mhz once the temp reaches 65c. The Temp. Limit is set to 92c on MSI Afterburner BUT I have found that the card thermal throttles the exact same whether it is set to the default temp limit of 83c or if the temp limit is raised to the max of 92c. I am new to overclocking and am very confused and would like to know why my card begins to thermal throttle way before it should. Any help is appreciated.
