So my GTX 780 has a burned capacitor and it doesn't show any signal from the monitor, sometimes it shows a blue screen of death, last time when it work it has artifacts for example like green lines. So i wonder would i be able to fix it?
Is there a way like using the heat gun/baking method? Do i have to remove the old capacitor and solder it with a new one?
The gpu is a Zotac GTX 780 amp edition.
Heres the last time when it work( as you can see there's some artifacts)
Heres a picture of the burned capacitor
