Question My Laptop wont turn on if wifi card in the motherboard is plugged
Apr 6, 2023
its really weird problem but recently i got my laptop back after screen replacement repair and i noticed wifi isnt working, so i troubleshooted software part and opened laptop to see if there's something wrong inside and i noticed the wifi card is unplugged when i plugged it back and tried to turn on latop it wont turn on at all like nothing happens after pressing power button and if i removed it laptop works perfectly fine. I also tried replacing the card with new one but it still doesnt work.......i dont know what to do anymore
In some of the laptops the wifi antennas are inside the monitor. Could it be that the antenna cables got damaged while replacing the monitor?
Also i'm not sure if just switching the antenna cables could lead to this issue...
