I'm using an Acer Aspire 5 A514-53G-50LY laptop with an Intel core i5-1035G1 processor and Nvidia MX350 GPU. when the game first launched there was no sign of slowing down until 1 minute of gameplay the game started to become laggy and when I checked the CPU clock using MSI afterburner the CPU clock dropped to 399 MHz and ThrottleStop showed a power limit at PL 1 in both Core and GPU, see my screenshot below.
I'm at Windows 10 Pro 22H2 build 19045.3803 btw if ur asking. As you can see the CPU temperature is at 65°C so it's currently not thermal throttling but power throttling instead this condition appears both while plug-in and on battery. See these TPL values below.
at the PP0 Turbo Time Limit is set to 0,0010 is this normal for this CPU? What does PP0 do anyway?
I have two culprits in mind about this issue number one is the battery because HWINFO shows a 41,5% wear level but I don't know how accurate is that number, and the second is there's something wrong with the charging IC or CPU and GPU power delivery.
Scouring the internet about similar problems I found no solution whatsoever. Updating BIOS, I'm at the latest BIOS. Disabling BD PROCHOT, this thing gets limited for a reason I don't want to take any risks because I need to use this laptop to write my thesis. Reinstalling Windows, it's the same reason.
I'm all out of ideas, maybe you can help me.
