Question My monitor was at first very smooth but after a while it's not like that anymore?
pumacs16
111
Hello!
My problem is:
I Buy monitor and first run and gameplay: csgo: fast run and smooth gameplay, and
after a while it's not like that anymore not smooth like the first game and my question is why?
My Pc:
Proc: I5 7400
Videocard: Gigabyte GTX 1050ti 4GB
Motherboard: MSI Z270 Gaming M3
Ram : 8GB DDR4 3000mhz HyperX, G.SKILL Aegis 8GB DDR4 3000MHz
Monitor ASUS VG248QG 165Hz G-sync
Supply: Corsair VS650
Latenymon:
https://ibb.co/djtV3Nx
https://ibb.co/f2G4hjS -CPUS
https://ibb.co/wrYzDvs -DRIVERS
Ok so the first thing I see in your 3d settings is you have Latency at Ultra. What this does is prevent your card from stacking frames up in advance to be used in line. I would turn that off. Your gpu is capable of producing 200-300 fps in the game no need to use this setting. Turn vsync off, keep your fps lock framerate and use g-sync. See if this smooths things out.
Reactions: pumacs16
it got worse.. there are micro lags and it's not that smooth
Micro lags could be your cpu is not keeping up with your gpu. Try using high performance in your windows power setting. That way your cpu is already ramped up to its full ability. See if that helps at all. Are you familiar with MSI Afterburner? Set up that app to monitor your cpu and gpu usage percentage, and any other you may be interested to see. What is the percentage when you play the games?
Reactions: pumacs16
Yes i sett.
Video: https://www.veed.io/view/934fbf3e-5b59-4065-bebd-1d348dc84ee6?sharingWidget=true&panel=share
Thing is, your GPU isn't powerful enough to get 60+ FPS @ 1080p. So, even when you have 165 Hz monitor, which can show up to 165 FPS (1 Hz = 1 FPS), your GPU is way too weak. Hence why your gameplay isn't smooth.
Now, if your GPU would be GTX 1660 Ti (like i have it), or RTX 3060 and up, then you can get 144+ FPS with smooth gameplay.
E.g here's comparison between your GTX 1050 Ti and my GTX 1660 Ti,
link: https://gpu.userbenchmark.com/Compare/Nvidia-GTX-1050-Ti-vs-Nvidia-GTX-1660-Ti/3649vs4037/retro bowl
See any difference? :)
Also, CS:GO can be hard on the CPU, so play on an empty server to see what your system can do visually when it's not being used for anything else. Since the CPU is in charge of how well the GPU works, I suggest this.
Reactions: pumacs16
