Question My monitors lose signal, and my pc freezes
alfie6209
Commendable
May 14, 2020
6
While playing games mainly and sometimes randomly ( but not as frequent) my monitors will disconnect and the pc will freeze however for like 30 seconds i can still hear and speak, so I went into event viewer to see the error:
The description for Event ID 0 from source nvlddmkm cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
\Device\Video3
Error occurred on GPUID: b00
The message resource is present but the message was not found in the message table
After seeing this i googled it and have so far updated drivers, factory reset pc, uninstalled and reinstall gpu on windows and yet the problem still occurs, do i have a faulty gpu what's the issue. This all started randomly, I have had the pc for about 4 months and have had no problems with this before.
And when i play for example valorant, i cant play even half a round before it happens again, but if i dont load a game i can use the computer for a while without issues, and to test the gpu wasnt getting overused, i stress tested it and it didnt crash.
SPECS:
NVIDIA GeForce RTX 3070
AMD RYZEN 5 5600X 6-CORE PROCESSOR
SSD - 555Gb free
16 GB DDR4 3600MHz
mobo - PRIME B550M-K
