A anil_24 Distinguished Mar 8, 2010 1 0 18,510 Mar 8, 2010 #1 sir my pc is not giving display and does't gives any weep that show any error so please give me any solution as soon as possible
G Guest Guest Mar 8, 2010 #2 Have you put in the correct type of memory module ? Also try resetting the BIOS -- usually a pin jumper near the backup coin battery (but check motherboard manual) -- or remove the coin battery for a couple of minutes. Upvote 0 Downvote
welshmousepk Distinguished Sep 12, 2009 3,437 0 21,160 Mar 8, 2010 #3 you have to give us mroe info if you expect us to help. full system specs please. does is power up? lights come in and fans spin? and also, what were you doing to cause this? did the pc work previously? is it a new build? or had you just changed something? give us some info, and we can help narrow it down. Upvote 0 Downvote
jsc Champion Jul 14, 2004 16,893 7 52,960 Mar 8, 2010 #4 No beeps means that the POwerup Self Test is not working. Our standard checklist and troubleshooting thread: http://www.tomshardware.com/forum/261145-31-read-posting-boot-problems Upvote 0 Downvote
