My pc doesn't start after cpu cooler change
Iraklis
Commendable
Feb 6, 2017
4
Hello today i try to change my cpus cooler(yes i apply thermal paste) i did it and then i try to open my pc but then my screen was black and keyboard-mouse had no power but everything else inside the pc was working properly(cpu fan other fans)also i noticed that when i start my pc o don't hear thedistinctive beep sound that i used to hear
PcRigs
34
If keyboard mouse had no power it mostly is because the BIOS post (power on self test) check is failing. Meaning that its not starting the computer because a major component is missing (its not detecting the processor fan?) So you have to check if it has been installed correctly. The distinctive sound stands for several reasons depending on motherboard, for example my motherboard beeps if it does not detect a display.
Iraklis
Commendable
Feb 6, 2017
4
Hello and thanks,i double and triple check everything but still nothing,i can't understand what is wrong also the sound that i speak about i think that is the sound of the processor,the cpus fan working properly but i don know if my motherboard recognizes it(i try both the old and the new)
Iraklis
Commendable
Feb 6, 2017
4
Yes and the odd thing is that the first time i assembly my pc i put it on the cha fan instead of cpu(i know rookie mistake,but i'm rookie after all)and it use to work just fine
The fan would work fine connected to any fan header, it's just regular fan after all. BUT the PC would think that there's no CPU fan and wouldn't start (well, at least it shouldn't, but some mobos might actually don't mind).
Did you uninstalled any components during cooler change? RAM perhaps? Is your motherboard equipped with beeper?
