my PC is using way more ram than normal
DefectedSOul
392
PC
Processor - AMD FX 8320 Black Edition (8 Cores @ 3.5GHz)
Graphics Card - AMD Radeon Sapphire R9 270X 4GB OC edition
RAM - 2x 4GB G.Skill Ripjaw X (8GB DDR3 @ 1866)
Power Supply - 850watt EVGA SuperNOVA G2
Motherboard - GIGABYTE 970A-UD3P
My pc normal uses around 20% of ram just running idle after start up but i turend it on and the ram usage is at 70% and im running AVG and Malware Bytes to see if its malware or a virus
any idea what could be causing all my ram to become used?
Well there are definitely some odd things here. At this point it might be easier to knock out the system and reinstall Windows than to pick at little bugs which could be tough to nail down. If you have the install disk and some time to re-do everything, that is the surest way to clear all these issues. Just make sure you save any files you don't want to lose on an external drive.
Short of that you could throw a bunch of other cleaners and antimalware programs at it, though the chances of success aren't 100%
It could be windows update, viruses or a memory leak. If it's windows update, it will settle down on its own. You should find it with the scans if it's viruses/malware. If it's a memory leak than check all of the programs that start with your computer and go from there, browsers and AV are normally the cause..
my cpu usages is around 1 to 20% and under processes its nothing i see out of the ordinary just normal stuff running tho there is some stuff running that im not to sure what it is like "dllhost.exe" and "ctfmon.exe"
at the top of the ram usage is msfeedssync.exe *32 and all the other stuff thats up top looks like mostly Windows or Microsoft stuff thats running
i dont use internet explore but I do get a pop up all the time saying it has stopped working
If you never use IE you can disable it, or you can attempt to repair the problem with system restore. If you remember when those errors started to appear, do a system restore to a point before then (this would change all your other settings back to that time as well and could change programs)
To disable IE, go to Programs in the Control Panel, select "turn windows features on or off" in the left-hand pane, OK the security message and uncheck the box next to Internet Explorer, then click Apply and restart.
If this doesn't fix your problems, there are other options up to reinstalling Windows
okays cool
i had a prosses runing called dvdupgrd.exe and i looked it up and it said that it was a bad to have and the file it was in seems weird "SysWOW64" is that whole folder safe?
http://greatis.com/blog/how-to-remove-malware/dvdupgrd-exe.htm thats where it said it was harmful
on the AVG scan it did find a Trojan horse downloader and everything that i see take up alot of ram if coming from that file i didn't know if it was an actual windows file
C:\Windows\SysWOW64 thats the address to that file on my PC
That site where you looked up "dvdupgrd.exe" looks a bit odd to me. It just looks like it's selling something and doesn't substantiate the claim that that's definitely a malware. As I said, just about any normal windows file can be taken over by an infection or replaced with a malicious version. The presence of the file doesn't tell us whether it's infected, though if it's using a lot of resources that seems odd.
ohhhh okay and i dont remember were it said it found it at its still doing the scan and its found 6 threats so far on it and i got malwarebytes runing aswell and its found 4 so far
do you think i should try deleting the SysWOW64 file? seems to have almost everything the Windows32 file has before i re install windows?
