My pc parts:
But then yesterday, while I was playing a game, my screen went black. I noticed the EZ LED was flickering on GPU and BOOT, while CPU and DRAM were steady, and there was a flickering sound coming from my PSU that was turning on and off repeatedly.
I turned it off and unplugged everything from the motherboard, then installed each part one by one, while still connecting the POWER_SW from the case to the motherboard (case fan not connected).
I also tried connecting just the motherboard, CPU, RAM, and case I/O (3 fans, audio, and power). When the PSU was on, 2 of the 3 fans turned on, and later only the top fan remained on. This didn’t cause the PSU to turn on and off, but the motherboard's EZ LED for GPU and BOOT flickered.
I also tried updating the BIOS, as I hadn't done it before, using Flash BIOS with version 7E26v19, and it was successful.
I'm not sure if the combination of my ARGB fan case, SSD, and motherboard is causing the black screen
What should I do?
- CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor
- CPU fan: be quiet! Pure Rock 2 CPU Cooler
- Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard
- RAM: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory
- Storage: Samsung 980 Pro 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive
- Video Card: ASRock Challenger Pro OC Radeon RX 6750 XT 12 GB Video Card
- PSU: MSI MAG A750GL PCIE5 750 W 80+ Gold Certified Fully Modular ATX Power Supply
- Case: Phanteks G300A ATX Mid tower case (with 3 fans installed)
- With the CPU and CPU fan installed and the PSU on, the CPU fan was running, and the EZ LED was on for CPU and DRAM.
- When I installed the RAM (I had 2 sticks, tried one by one), the CPU fan was still running with the PSU on, and there was no change in the EZ LED, which remained on for CPU and DRAM.
- When I installed the SSD, the issue appeared. With the PSU on, the EZ LED for GPU and BOOT continuously flickered, and the PSU failed, making a clicking sound repeatedly turning on and off.
What should I do?
