[SOLVED] My PC turns off some seconds after I turn it on? Help!
Dec 11, 2020
16
so my pc started turning off some seconds after I press the power button.
Specs
Asus H81m-c motherboard
Asus GTX 1060 3G
I5 4460 intel processor and intel fan cooler
16 Gigs of ram
Corsair 550-watt PSU
1 Terabyte disk
video of my problem
Specs
Asus GTX 1060 3G
16 Gigs of ram
1 Terabyte disk
video of my problem
While I can't be 100% sure, I'd suspect the power supply. It's an old, low budget model and not very good to begin with.
Check all the connections on the mobo , some may have move a tiny bit as heat has circulated round the case.
I caught the edge of a fan plug whilst removing dust , just enough to stop the fan working.
The pc shut down because it could not find all the component's it was looking for.
