my problem is same, but there is no button under my laptop .. my laptop is asus x550D
sepatu
Commendable
Sep 20, 2016
i want to charge my laptop but it always plugged in, not charging .. it's always 80% .. my laptop is non removable battery .. my laptop is asus x550D
Well, technically, all batteries are removable, just always easily. :)
If the laptop is still under warranty, I would suggest contacting the manufacturer. If it isn't under warranty still, then try this.
Make sure the laptop is off, and try and charge the battery. Does it charge completely then? If yes, then try using another charger cord, when it is on, and see if it will charge the battery. If it still charges, then your cord is/was the problem.
Now if neither of those work, then it is probably the battery.
