My System Fan cable caught fire
Jay9
65
Well.... dunno what to make of this.
Recently got a GTX 660. Decided to bench mark Far Cry 3.
Even framerates, nicely smooth. Let's tense it up. I go into a massive firefight. I look over and see the bridge between my System Fan, GPU, and PSU on fire.
Any idea what the actual hell happened?
**I had both the System Fan's power input and my GTX 660's power input on a splitter cable**
I reckon thats why the fan cable melted, Gfx card wanted to pull some hefty juice and overloaded the fan cable,
Never have anything on the same cable as gfx cards if you use molex lines for Gfx cards
Moto
Seems to be a common issue. I searched up for the terms AFCI breaker and Power Supplies and others seem to have it.
It's basically the AFCI breaker being too sensitive to the PC booting up and tripping the connection to my room.
This is also why it didn't trip in other rooms because I tested it in a living room. Turns out AFCI are mainly installed in bedrooms.
I'm replacing this PSU with a Corsair 750W in hopes that it'll be less intensive on starting up along with a UPS to keep the current spike in reason between the outlet and the PSU itself. This is really the only thing I can think of.
I've used a vacuum multiple times, never tripped. I guess I'll only really know after this PSU gets here. I also read the PFC is supposed to prevent things such as this. Maybe it's a bad PFC switch in this Seasonic?
That's why I asked if you tested it on a different circuit within your home. The inrush current during start up of the PC is what trips your AFCI.
You can also put in a separate circuit with a normal breaker just for your PC. It's an expensive solution though.
I took the suggestion of a new PSU and a UPS. Would you think this to suffice?
It's not guaranteed that it'll solve your problem.
Make sure you buy a UPS that is compatible with your PSU's APFC circuit or you'll just be introducing another problem.
You can't tell unless you've personally tested the combination or you've found a PSU review that has tested the specific PSU with a UPS that outputs a stepped approximation to a sine wave. Even power supply manufacturers don't provide UPS compatibility information.
X-bit labs is one review site that performs such a UPS Compatibility Test when they review a PSU.
