My system specs for 3d modelling and rendering, review needed!
Shanikata
My system specs are as follows:
processor: i7 4770k
mobo: Asus gryphon z87
GPU: Sapphire HD 7950 3gb boost
Ram: G.Skill 4gb X 2 Kit F3-12800CL9D-8gbSR 1600 mhz. Sniper
PSU: Corsair 750W AX750 Professional Gold
HDD: WD SATA 2TB Black Caviar 64 MB Cache
will the above configuration suffice my needs for modelling and rendering, My models are high poly count hence was suggested to go for a higher memory graphics card but due to shortage on cash have come up with this configuration! Also if any other alternatives for the graphics under the same budget as the hd 7950, please do suggest!
I would go NVIDIA for rendering, CUDA helps out with that. I'm not sure which exact Sapphire card you were looking at, but you can get a 780 around there I believe. This would be better. Also, for modelling and rendering, 16GB of RAM would probably be worth it too if possible.
