[SOLVED] My WiFi Keeps Disconnecting and Reconnecting.
joshisaca
5
And before you ask. Trust me. I've tried all of the common fixes for this topic. None of them worked.
  • Uninstalling my Wifi Driver (Didn't work)
  • Roll backing (Didn't Work)
  • Disabling (didn't work)
  • Updating Definitely didn't work.
Anyone has a fix to this? Or anyone can relate?
Sounds like either a weak connection or possible interference
Try downloading a free wifi analyzer App on your smart phone and see what your signal looks like. In an ideal situation a very good signal reading should be between -45 and -70 dbmv
Also, Not sure if you are using a dual band router or connecting on 5 GHz or 2.4 GHz.
But each will act a bit differently
2.4 GHz signals travel further but are prone to more interference, while 5 GHz has less chance of interference but doesnt travel as far
