hi there posting my specs again seeing if yall can help me out a bit with getting a pretty decent graphics card maybe $100-200 (if possible) just let me know with some links and everything. i also do not know how to check what kind of power i have in my computer. do i have to open it up manually or will CPU z show it? thanks you again and here are my specs.
CPU: intel pentium D 946
core voltage 1.247 V
Intel(R) Pentium(R) D CPU 3.40GHz
core speed: 2400.1 MHz
multiplier x12.0
bus speed 200.0 MHz
Rated FBS 800 MHz
MainBoard: model : OEMD975XLAG1 AAD50908-200
chipset: intel i975x
memory: dual channel 4x 2gb memory stick total 8gb
graphics card (right now) : Nvidea GeForce 8400gs 1024 mb
clock:
core 135 MHz
shader 1402 MHz
memory 333 MHz
so if this is a little bit more helpfull in my machine i also gave the model number to if that helps a bit too. i also have 64 bit system.
so any information on what kind of graphics card my computer can handle and maybe some places to get them (links)
anything helps !!! thanks again
Bryce
multiplier x12.0
bus speed 200.0 MHz
Rated FBS 800 MHz
clock:
core 135 MHz
shader 1402 MHz
memory 333 MHz
Bryce
