Need a good quality 550 watt PSU, fully modular if possible
hijackxd21
Proper
May 4, 2018
62
Hello, building my gaming pc and I need a 550 watt power supply that is preferably fully modular, please. I'd say no more than 60-70 CAD? If it isn't possible to get a good quality one at this price point I can go a little higher. Thanks in advance :D
Rexper
Respectable
BANNED
Apr 12, 2017
2,142
386
What are your full system specs? We need to know to ensure compatibility. You may not even need 550. Why fully modular, are you replacing the cables? Otherwise semi-modular should be fine.
For $60-70 CAD you’re looking at the Corsair CX450M/CX550M. Next option would be the Cooler Master MasterWatt
hijackxd21
Proper
May 4, 2018
62
Yes, I am replacing the cables with these:
https://cablemod.com/product/cablemod-e-series-g2-p2-basic-cable-kit-black-white/
Also getting this gpu backplate since I'm going with a dragon white and black themish build:
https://www.v1tech.com/shop/backplates/msi-dragon-backplates/
bignastyid
If you want to use those cables you'll need a PSu that is compatible with them. The Seasonic I posted above will not work with those cables, you'd have to get a set of cables made specifically for that PSU or series.
The least expensive PSu that works with thew cables you listed is the 550w EVGA G2(which is a good PSU)
https://ca.pcpartpicker.com/product/qYTrxr/evga-power-supply-220g20550y1
Rexper
Respectable
BANNED
Apr 12, 2017
2,142
386
That Seasonic 620 isn’t good, don’t bother.
There aren’t any quality 550w fully modular power supplies under $100 CAD, otherwise you’re looking at EVGA G2/G3, Focus Plus.
Remember not to mix modular cables. The cable mod you linked should only be used for EVGA G2/G3/P2/T2. Different power supplies have different pinouts.
bignastyid
That Seasonic is just fine, it's an older unit but still good. Go spout your personal crusade against anything group regulated elsewhere as I and many others are getting rather sick of it.
hijackxd21
Proper
May 4, 2018
62
Woops, probably forgot to mention that I was going to use this power supply before someone told me it wasn't worth 100 dollars:
https://www.amazon.ca/EVGA-Modular-Warranty-Compact-220-B3-0650-V1/dp/B071R9Z77W/ref=sr_1_10?ie=UTF8&qid=1529154623&sr=8-10&keywords=650+watt+power+supply+modular
That's also why I linked those cables since I had them bookmarked.
So i guess i should just get this one? Or the 550 watt version? It's only 14 dollars cheaper, but I don't know.
Thanks for all the help everyone!
bignastyid
The B3's are something I'd avoid. Tom's had 3 of them pop during testing. It is also not compatible with that cable kit.
hijackxd21
Proper
May 4, 2018
62
Oh wait I read it wrong LMAO I thought it said g3. Sorry about that. So I guess I'll just get the g2 you linked above. Thanks!
Just a small question: what do the g3 and g2 stuff mean? Does the higher number mean a better quality PSU?
Rexper
Respectable
BANNED
Apr 12, 2017
2,142
386
Higher number is a newer version, not necessarily better. You have to be careful with EVGA power supplies, a small difference in name can mean a big difference in quality.
G2 and G3s are very good performing, but the G3 has some issues with protections.
Find professional reviews specific to the model.
bignastyid
The G3 is a newer version and is slightly smaller, but there are reports the fan can get noisy. So a G2 vs a G3 where the G2 is the same price or less I'd definitely get the G2.
