Need a speaker with high quality crisp sound
For accuracy, at a decent price, try M-Audio AV 30 or 40 speakers. They are a bit larger but sound great. Any of the M-Audio powered speakers are pretty good, and you can find them used at a good price.
I have a set of AV 30 and although the bass is not great, the response is very even and they are very musical sounding. The AV 40 have a larger speaker and should give more bass output with the same clean sound.
Since you didnt tell your budget I got these for you
Corsair Gaming Audio Series SP2500 High-Power 2.1 PC Speaker System (CA-SP211NA)- 213$ http://www.amazon.com/Corsair-Gaming-High-Power-Speaker-CA-SP211NA/dp/B004H0MQYW/ref=sr_1_2?ie=UTF8&qid=1392623305&sr=8-2&keywords=gaming+speaker+pc
Genius GX-Gaming 5.1 Surround Sound 80 Watts Gaming Speaker System with Remote Control (G5.1 3500)- 116$ http://www.amazon.com/Genius-GX-Gaming-Surround-G5-1-3500/dp/B00BJE3WEW/ref=sr_1_11?ie=UTF8&qid=1392623305&sr=8-11&keywords=gaming+speaker+pc
Coby CS-MP77 75-Watt High Performance MP3 Speaker System (Discontinued by manufacturer)- 43$ http://www.amazon.com/Coby-CS-MP77-Performance-Discontinued-manufacturer/dp/B000P1D7O0/ref=sr_1_16?ie=UTF8&qid=1392623305&sr=8-16&keywords=gaming+speaker+pc
