[SOLVED] Need a Suggestions for motherboard in my PC Build
May 19, 2021
Hey Guys,
The first time I've ever come here, I'm building my first gaming PC. So as you can see I have a bit of a problem with my motherboard. Would you be able to assist me in suggesting something best alternative of ASUS ROG STRIX X399-E or is it fine? because I need a good & fast motherboard at a reasonable price for my new build?
1. Processor: AMD Ryzen Threadripper 2950X Processor 16 Cores & 32 Processing Threads, with Cooler ($799.00 @ Amazon US)
2. Motherboard: ASUS ROG STRIX X399-E GAMING AMD Ryzen Threadripper TR4 DDR4 M.2 U.2 X399 EATX HEDT Motherboard with onboard 802.11AC WiFi, USB 3.1 Gen2, and AURA Sync RGB Lighting ($726.99 @ Amazon US)
3. CPU Cooler: Corsair H100i RGB PLATINUM AIO Liquid CPU Cooler,240mm,Dual ML120 PRO RGB PWM Fans, ($197.00 @ Amazon US)
4. Case: Lian Li O11 Dynamic XL ROG Certified ATX Full Tower Gaming Computer Case ($235.07 @ Amazon US)
5. Graphics Card: EVGA GeForce RTX 2080 Ti Ftw3 Ultra, Overclocked, 2.75 Slot Extreme Cool Triple + iCX2, 65C Gaming, RGB ($3,190.00 @ Amazon US)
6. RAM: G.SKILL Trident Z RGB Series, 16GB (2 x 8GB) DDR4-4000MHz Desktop Memory with CL17 ($250.39 @ Amazon US)
7. Storage: SAMSUNG EVO 970 Plus 2TB PCIe NVMe M.2-2280 Internal Solid State Drive with V-NAND Technology & 1024MB Cache ($299.99 @ Amazon US)
8. Case Cooler: NZXT AER RGB 2 - HF-28140-B1 - 140mm - Advanced Lighting Customizations - Winglet Tips - Fluid Dynamic Bearing - LED RGB PWM Fan for Hue 2 - Single ($29.99 @ Amazon US)
9. Power Supply: Corsair RM 850 Series, 80+ Gold Certified 850W Fully Modular Power Supply ($134.94 @ Amazon US)
Total: $5,973
Generated by PC Builder on 8th of Nov 2021
Hey Guys,
3. CPU Cooler: Corsair H100i RGB PLATINUM AIO Liquid CPU Cooler,240mm,Dual...
Hey Guys,
Total: $5,973
Is there a special reason for using Threadripper ? One of best reasons for it is being able to use a lot of memory ny you are getting only 16GB. Considering your GPU it's probably for gaming and R9 5950 would be much better and cheaper.
Otherwise, there are no faster or slower MBs, they will all give you about same (invisible) performance.
