Guys my PC master race sensibilities have been violated and I need help, especially if you have experience with Destiny 2.
TL;DR: I've been getting into Destiny 2, a game that even with OC and tuned graphics settings is maxing out all 4 cores on my CPU and causing unacceptable frame drops as a result. GPU is not a problem. Looking for upgrade suggestions. See "Getting to the point" section at the bottom to skip the lengthy discussion, specs are at the top.
First of all my (current) specs:
CPU: i5 4690k @ 4.0ghz/1.15v
Cooler: Zalman CNPS5X (I currently have a better 212 Evo but it won't fit in the case I have by a margin of 4 mm :/)
Mobo: Asus Z97p
Ram: 16gb
GPU: MSI GTX 1080
PSU: Corsair 600w
Storage: 3x assorted size SSDs
OS: Windows 8.1
Monitor: I am a 1080p 60hz noob
So on to the problem at hand. Destiny 2 went free 2 play in the beginning of Oct and I've been getting really into it and plan on staying with it long-term. The problem I've been experiencing is that the game was loading up all 4 cores on my poor 4690k @ 3.5 ghz and I started noticing some intrusive frame drops down into the low 30's (only in the most demanding situations). GPU is only at ~60% usage. I decided to OC and realized some increase in fps stability, but not enough.
After doing some research I've found that Destiny 2 should make use of more than 4 cores (maybe it will use 8, not sure). With that in mind, I've been looking at ryzen CPUs and I'm really not sure where I should spend my money. I'm kinda stuck between 2700x, 3600x, and 3700x. I know people who stand by the 3700x and some say it has as much as 10-15% real world fps increase over the 2700x. I don't understand how since the clock speeds and core count are similar (I know that's not everything and maybe someone can enlighten me). With the minor real-world performance difference aside, the 2700x is nearly half the price ($189 vs $329) so I'm inclined to go that route. The main disadvantage I think is TDP, but should I really care? Ultimately what I'm concerned about is increasing my core count so I'm not fully loading all cores. Per-core frequency is useful but I don't think that's the main issue in this scenario.
Getting to the point:
Any feedback is greatly appreciated. I've put in several hours researching already but would like second opinions so I can avoid making mistakes.
Cheers,
Indy
Mobo: Asus Z97p
Ram: 16gb
GPU: MSI GTX 1080
PSU: Corsair 600w
OS: Windows 8.1
Using afterburner I was able to find that the frame drops always coincided with all cores at 100% while the GPU usage was under 50% so it's a simple CPU bottleneck. I overclocked to 4.0ghz, the max stable OC with acceptable temps on my admittedly sub par cooler, i.e. ~75C avg (pushing 4.2ghz was requiring 1.25v and 83C+ temps so I backed off idk if bad chip, bad cooler or both). I researched all CPU intensive settings and lowered them to minimum or turned them off. I also have VSync on (otherwise there is horrible tearing) and framerate cap at 60. The performance is noticeably better after OC but there are still occasional drops ~45fps and I had a 1-time 28fps drop (which I'm chalking up to having chrome open with like 15 tabs eating CPU).
These are the CPU/GPU usage graphs from afterburner in a scene that runs reasonably well with a couple drops to 45- 50fps and I would say is average for Destiny 2 in terms of CPU demand.
The only reason the GPU usage even exceeds 50% is because I have resolution scale at 200% which I have found to have no noticeable impact on CPU but utilizes more of the gtx 1080s power while making up for the fact that the antialiasing in Destiny 2 is garbage. Lowering res scale to 100% did not lower CPU usage, nor did it improve performance.
- I would like to get the upgrade done ~$400 (case, mobo, cpu, ram) but I can be flexible if better components are worthwhile (I'm looking at you 3700x)
- Should I go with Ryzen 2700x, 3700x, or something else entirely? I'm looking to only spend money for reasonable performance gains.
- What are recommendations for a reasonably priced new mobo (I am partial to Asus, but open to anything non-MSI. Also I am a storage hog so the more SATA/M.2 slots the better)
- Any thoughts on good priced 2x8 GB RAM kit with appropriate speed the CPU can take advantage of?
- Once I have the parts ready, I know I will need to upgrade to Win 10. Once I do that, any tricks to booting an existing OS with a new mobo/CPU installed?
Cheers,
Indy
