APPROXIMATE PURCHASE DATE: (Should be built in the next Month) BUDGET RANGE: (example: US$1300-1500)
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, Multitasking, Internet
PARTS NOT REQUIRED: Monitor, Speakers, OS
PREFERRED WEBSITE(S) FOR PARTS: Newegg.com. or what ever is cheapest
PARTS PREFERENCES: Intel i7, Nvidia
OVERCLOCKING: I want to
IM OPEN TO ALL SUGGESTIONS
THE BUILD
********WAITING TO BUY LIST******
what else should i get or what should i upgrade
2. EVGA 896-P3-1170-AR GeForce GTX 275 896MB 448-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.244962
XIGMATEK Dark Knight-S1283V 120mm Long Life Bearing CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029
GIGABYTE GA-EX58-UD3R LGA 1366 Intel X58 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128375
mushkin 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Triple Channel Kit Desktop Memory
www.newegg.com/Product/Product.aspx?Item=N82E16820226036
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181
Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
Sony Optiarc Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 48X CD-R 32X CD-RW 2MB Cache SATA DVD Burner with LightScribe LightScribe Support
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118032
(i want to max out my Antec 1200s fan options) So how many more could i install?
APEVIA CF12SL-UBL 120mm Blue LED Case Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16811998121
ARCTIC COOLING MX-2 Thermal Compound
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186020
******ALREADY PURCHASED*****
1. Intel Core i7 920 Nehalem 2.66GHz LGA 1366 130W Quad-Core Processor Model BX80601920 - Retail http://www.microcenter.com/single_product_results.phtml?product_id=0302727
1. Antec Nine Hundred Black Steel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021
CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
Saitek PZ30AU Black 104 Normal Keys 4 Function Keys USB Standard Eclipse Keyboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16823175103
Logitech MX518 8 Buttons 1 x Wheel USB Wired Optical 1800 dpi Gaming-Grade Mouse
http://www.newegg.com/Product/Product.aspx?Item=N82E16826104178
RAZER RZ81-00030101-B2M1 eXactMat and eXactRest Bundle - Mouse Pad and Wrist Rest
http://www.newegg.com/Product/Product.aspx?Item=N82E16826999019
RAZER Carcharias 3.5mm Circumaural Professional Gaming Headset
http://www.newegg.com/Product/Product.aspx?Item=N82E16826153043
thank you for the help. Just remember everyone was a newb at one point. hehe
THE BUILD
