Question Need advice on a graphics card for a Dell XPS 8940
Mar 12, 2025
I have a Dell XPS 8940 that is about 3 years old. Its an i7 with 16GB RAM, and integrated graphics (intel UHD 750 I think). Looking for a basic card that will allow me to run fort_nite. The current configuration runs it, but can be slow sometimes. Need one with an HDMI and DisplayPort connectors for my 2 monitor setup (only use the monitor with the DisplayPort for fort_nite). The power supply is 360W, and from what I've read, is not upgradable.
I'm by no means an expert, but from what I've read online, I need a graphics card the doesn't require a separate power connector, so it gets all its power from the PCIe x 16 slot. Searching online, I see some cards that pop up are the GeForce GTX 1650 or RX 6400.
So a couple questions:
1) What would be the best card that doesn't need external power?
2) Do I need that "best" card for fort_nite?
3) Will any graphics card that doesn't require external power work in this PC, or is there other specs that would exclude it? I understand the power supply is not beefy enough to support high end cards.
Would appreciate any advice.
Which i7 do you have;
https://www.dell.com/support/manual...acb88f-e7e3-4702-8a22-92ec94f89dd4&lang=en-us
1| If you look here;
https://www.dell.com/support/manual...9f07ce-626e-44ca-be3a-a1fb036413f9&lang=en-us
those are the cards that are open to you.
2| No.
3| You copuld look at this thread;
https://www.dell.com/community/en/c...r-supply-replacement/654d6144d3ea417c9705b0f6
and perhaps look at an RX 6600 XT
I looked and found that I have a 11th Generation Intel Core i7-11700.
Thanks for the quick response. These are some helpful links. I'll take a look at the RX 6600 XT
A lot of cards will run Fortnite
"The recommended system requirements for Fortnite on PC include a Windows 10 or 11 64-bit operating system, an Intel Core i7 8700 or AMD Ryzen 7 3700X processor, 16GB of RAM, and a Nvidia GeForce RTX 3070 or AMD Radeon RX 6700 XT graphics card."
In my experience a lot of Dell's have poor power supplies and you might need an upgrade if you run into issues. See what yours is rated for.
Dell XPS 8940
Power ratings
Type360 W
Input voltage90 VAC–264 VAC
Input frequency47 Hz–63 Hz
Input current (maximum)5 A
According to this ebay page it has an 600 watt replacement for the Dell 8940.
https://www.ebay.com/itm/2860989980...n31ugo_IGZNKnkzoMWb6g6Pkf1DF9rHMaArJGEALw_wcB
View: https://imgur.com/34f8GaM
Thank you. This gives me a couple options. I'm going to check the connectors on my systems and see if these match up. Might allow me to get a better graphics card.
