Ok, so I'm building my first gaming rig on a pretty small budget of 700 bucks. I really don't want to go over that price of 700 but if I must I suppose I shall. I've been doing a lot of research on different builds with a budget and so far newegg has been pretty good with the combo deals for cutting prices down on individual parts.
Here is what I have so far, I'm just stuck at what video card I should use.
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM - $17.99
NZXT Source 210 S210-002 White w/Black Front Trim “Aluminum Brush / Plastic” ATX Mid Tower Computer Case - $39.99
Logitech K120 Black USB Wired Standard Keyboard - $13.99
CORSAIR Vengeance 4GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ4GX3M1A1600C9B - $24.99
ASRock H77M LGA 1155 Intel H77 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard - $84.99
Samsung by Seagate Spinpoint F3 HD502HJ/ST500DM005 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
CORSAIR Builder Series CX500 V2 500W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
Item #: N82E16817139027 - both HD and PSU are combo deal of $129.98
Intel Core i3-2120 Sandy Bridge 3.3GHz LGA 1155 65W Dual-Core Desktop Processor Intel HD Graphics 2000 BX80623I32120
CORSAIR CWCH60 Hydro Series H60 High Performance Liquid CPU Cooler - both CPU and CPU liquid cooler combo deal of $172.98
all of this together comes to a toal of $507.44 (including shipping).
My question is what kind of graphics card should I get. I am looking to do some work in photoshop/video editing. Nothing too serious just something to do on the side. I also want a computer that can handle Skyrim at pretty good settings, doesn't have to be performing perfectly just enough to play comfortably in most high end games.
I chose the Intel I3-2120 over a cheaper amd processor because I figured Intel is the way to go if I plan on upgrading later. I also read that it runs cooler.
So far the evga gtx 560 looks affordable at $189.99. I've never built a computer before so I'm not too sure. I was considering the gtx 550ti but I've read that I should probably just cough up a little more for a better card that will last me longer.
Any suggestions on my build, or what graphics card I should be looking into would be greatly appreciated.
