What do you guys think? My budget is $700 Canadian. I will be using this for some gaming like BFBC2, COD, Total War Games.. and some internet surfing.
Sony Optiarc 24X DVD/CD Rewritable Drive Black SATA Model AD-7240S-0B - OEM http://www.newegg.ca/Product/Product.aspx?Item=N82E16827118030
COOLER MASTER Elite 360 RC-360-KKN1-GP Black Steel / Plastic ATX Mini Tower Computer Case http://www.newegg.ca/Product/Product.aspx?Item=N82E16811119195
Seagate Barracuda 7200.12 ST3500418AS 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive http://www.newegg.ca/Product/Product.aspx?Item=N82E16822148395
GIGABYTE GA-785GMT-USB3 AM3 AMD 785G USB 3.0 HDMI Micro ATX AMD Motherboard http://www.newegg.ca/Product/Product.aspx?Item=N82E16813128432
SAPPHIRE Vapor-X 100284VXL Radeon HD 5750 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card http://www.newegg.ca/Product/Product.aspx?Item=N82E16814102865
Antec NEO ECO 620C 620W Continuous Power ATX12V v2.3 / EPS12V 80 PLUS Certified Active PFC Power Supply http://www.newegg.ca/Product/Product.aspx?Item=N82E16817371031
A-DATA Gaming Series 2GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model AX3U1600GB2G9-CG http://www.newegg.ca/Product/Product.aspx?Item=N82E16820211450
AMD Athlon II X3 435 Rana 2.9GHz Socket AM3 95W Triple-Core Processor Model ADX435WFGIBOX http://www.newegg.ca/Product/Product.aspx?Item=N82E16819103724
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM http://www.newegg.ca/Product/Product.aspx?Item=N82E16832116754
Total = $691.42
NEED ADVICE ON THIS BUILD.. THANKS
Total = $691.42
