BUDGET RANGE: $750-$840
USAGE: Mostly playing fortnite and streaming. sometimes playing overwatch without stream.
CURRENT GPU AND POWER SUPPLY: RX 580 4GB. And i cant decide what power supply i have 🙁
CPU: AMD Ryzen 5 2600
Memory: 24 GB 2400 mhz
Monitor: 2 monitors. Main monitor (144 hz) second monitor (60hz)
Im looking for an advice regarding which GPU i should buy and how can i make use of my current budget efficiently. For example, im thinking of buying an RTX 2060 due to its low price when compared to a 1070 ti even though im not going to use the RTX option (going to turn it off since the games i play dont have an RTX option). And also get a liquid cooling system to overclock my CPU with a decent Temperature ( probably the a360 kit ). Finally, change my memory ram to a higher speed( from what i heard that Ryzen works best with 3000 + mhz)
what do you guys think? would really appreciate the help!
