Hello everyone,
For the past month I have been constantly tweaking these two builds, and I think they are finally good. I would like to run Mac OS X Snow Leopard, then use Boot Camp for Windows 7 to play games, or dual boot.
I would like to be easily able to upgrade in the future, switching out video cards, adding RAM, etc.
So, the question is, my Intel build, or my AMD build?
Approximate Purchase Date: Within a month
Budget Range: ~$750
System Usage from Most to Least Important: Gaming, Everyday Use (Internet, iTunes), School use
Parts Not Required: Keyboard, Mouse, OS
Preferred Website(s) for Parts: Preferably Newegg.com, but I'm also open to Amazon.com and Tigerdirect.com
Country of Origin: USA
Parts Preferences: None really
Overclocking: Probably not for now, this is my first build after all.
SLI or Crossfire: Not for now.
Monitor Resolution: The monitor I'm going to get says 1600 x 900
Additional Comments: What do you guys think? Here are the two builds:
INTEL BASED BUILD:
Processor: Core i5 2400 Sandy Bridge 3.1GHz Quad-Core - $189.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115074
Motherboard: ASRock H61M-VS LGA 1155 Intel H61 Micro ATX Intel Motherboard - $59.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157241&Tpk=h61m-vs
Graphics Card: Sapphire Radeon 6870 HD 1GB GDDR5 (Comes with free Deus Ex: Human Revolution game coupon) - $174.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102948
RAM: G.SKILL Ripjaws Series 4GB DDR3 1333 SDRAM - $24.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231310
Hard Drive: Seagate Barracuda 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive - $74.48
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.696141
Power Supply: Rosewill 600W ATX12V v2.01 SLI Ready - $94.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.693970
Case: Rosewill Challenger ATX Gaming Mid-Tower 3 fans, 1 top, 1 front, 1 rear, option to add two on the side
(See Power Supply)
Disc Drive: Asus DRW-24B1ST/BLK/B/AS Black Sata 24X DVD Burner
(See Hard Drive)
Wireless Adapter: TP-LINK 802.11b/g/n up to 300Mbps - $24.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16833704053
Monitor: Acer Black 20" 5ms LED Backlight, LCD Monitor (1600 x 900) - $109.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009256
Speakers:Logitech S120 2.3 Watts (RMS) 2.0 Speaker System - OEM - $16.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16836121013&Tpk=logitech%20s120%202.3%20watts
Total Cost: $772
AMD BASED BUILD:
Processor: AMD Phenom II X4 965 Black Edition (Comes with free Battleforge Game Coupon) 3.4 GHz Quad-Core - $129.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
Motherboard: BIOSTAR A870 AM3 AMD 870 SATA 6Gb/s ATX AMD Motherboard - $59.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813138324
RAM: G.SKILL Sniper 8GB (2 x 4GB) DDR3 1333 SDRAM - $48.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231417
Case: Rosewill Challenger Black Gaming Case, ATX, 3 fans, 1 top, 1 front, 1 rear, option to add 2 in the side
(See Power Supply)
(See Hard Drive)
Speakers: Logitech S120 2.3 Watts (RMS) 2.0 Speaker System - OEM - $16.99
Total Cost: $736
So, what do you guys think I should go with? Intel, or AMD? Again, keep in mind I would like to dual boot Snow Leopard and Windows 7, or use Boot Camp, but I want a good gaming PC that I can upgrade when I need to, and preferably the build should last for a few years running games on decent to high settings.
Thank you to anyone who helps me decide.
Budget Range: ~$750
INTEL BASED BUILD:
(See Power Supply)
(See Hard Drive)
Total Cost: $772
AMD BASED BUILD:
(See Power Supply)
(See Hard Drive)
Total Cost: $736
