First the specs:
CPU - AMD FX Vishera 9590
MB - ASUS Sabertooth 990FX R2.0
RAM - G.SKILL Ripjaw X Series 32 GB
GPU - ASUS Direct CU II Radeon R9 270x 2GB
PSU - Cougar GX1050
OS - Windows 8.1 Pro
So, about a week ago I got several display driver failure type black screens (with the odd uniform verticle lines). I Installed the new 14.9 AMD driver after using DDU to completely remove 14.4. I had read there were some issues with the normal removal of 14.4. But my issue only changed. Instead of the driver failure black screen, my entire system would freeze. Oddly enough the first time this happened the song I was listening to continued to play, but the next song never started. So I thought, this is a good time to install that SSD I bought. I wiped everything, complete format of all my drives. I'll save you some time (it turns out my SSD was bad). SO! Fresh install windows, start loading up all my goodies, and some time after my AMD driver install it freezes again. So after a couple retries at this, it has definitely sunken in. My system only freezes after I install my AMD drivers.
I can usually figure out my computer woes with my basic knowledge and my friend Google. But I'm out of my depth here. I am thinking it's the graphics card itself that is the problem, but unfortunately I don't have another card to test the rest of the system with. I can't pull any dump files, that is to say none have occurred as it doesn't go to BSOD (at least that's my understanding). So what can I do? Btw you are all incredibly handsome/beautiful and brilliant.
PSU - Cougar GX1050
