need build for skyrim
jtuwood
16
Approximate Purchase Date: ASAP
Budget Range: $850-$1000
System Usage from Most to Least Important:Gaming
Parts Not Required:keyboard, mouse, monitor, speakers
Preferred Website(s) for Parts: newegg.com
Country: U.S.
Parts Preferences:Geforce graphics card, intel processor
Overclocking:maybe
SLI or Crossfire:IDK :/
Monitor Resolution:1920x1080
Additional Comments:
Just made a final edit, and yes this should max skyrim easily, if you added a few dozen graphical mods though, then probably high settings would be manageable
Switching everything to newegg made it a bit more expensive...
This is just a go crazy build (not too balanced though)
http://pcpartpicker.com/p/1WyQ8
EDIT: added an SSD for quick booting
http://pcpartpicker.com/p/1WyXW
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($239.99 @ Newegg)
CPU Cooler: Xigmatek GAIA SD1283 56.3 CFM CPU Cooler ($31.99 @ Newegg)
Motherboard: ASRock Z87 Extreme3 ATX LGA1150 Motherboard ($119.99 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($63.75 @ Newegg)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Disk ($89.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ Newegg)
Video Card: Asus GeForce GTX 760 2GB Video Card ($255.66 @ Newegg)
Case: Cooler Master Storm Enforcer ATX Mid Tower Case ($89.99 @ Newegg)
Power Supply: Antec High Current Gamer 520W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($50.99 @ NCIX US)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($14.99 @ Newegg)
Total: $1027.33
(Generated by PCPartPicker 2013-11-02 21:01 EDT-0400)
Thanks :) and this should play skyrim pretty well with mods? Id like to play it on atleast high
yes the 4670k cpu is great but if you go amd get 8320 and ram 1866 no less can get a cheap z87 mobo or if you go amd get 990fx any 1 i like asus msi and biosatr can be good i also like kingston and gskill ram from 1333 and 1866and the what other guy had you can get a 7950for good price if you look
You could look into a cheaper case if you want to 😀
http://pcpartpicker.com/parts/partlist/
Case: Thermaltake Commander MS/I Snow Edition (White/Black) ATX Mid Tower Case ($38.98 @ Newegg)
Power Supply: Thermaltake SMART 550W 80 PLUS Bronze Certified ATX12V Power Supply ($55.98 @ Newegg)
Total: $981.31
(Generated by PCPartPicker 2013-11-02 21:09 EDT-0400)
