Okay I have posted probably 3 times in the past week. I am trying to get this computer build down and really buckle down on whats needed or whats not needed etc. I need all the help I can get, and thanks again everyone! The main issue is this, I am trying to figure out if I should go with the GTX 680 4 gb DDR or go with a dual Radeon 7970 with the following build and if anything else would of course need to be changed. starting early on the new ROME TOTAL WAR II would like to be able to play ultima settings, big armies etc
Intel Core i5 Processor i5-3570K 3.4GHz 6MB QUAD
CORE ZALMAN COPPER DELUXE EDITION COOLER (or an Evo 212) not sure what I should do.
LGA 1155 ZEROtherm Advanced ZT100 Thermal Grease
(going with better wiring) PROFESSIONAL WIRING
(This is over Kill maybe? but what can I expect to keep going for 5 years) Asus P8Z77-V PRO LGA1155/ Intel Z77/ Quad CrossFireX & Quad SLI/ SATA3&USB3.0/ WiFi/ A&V&GbE/ ATX Motherboard
16GB (2 x 8GB) 240-Pin DDR3 1600MHz (PC3 12800) Dual Channel
(2X) MEMORY HEAT SPREADERS
CORSAIR 120GB Solid State Drive SATA III (READ/WRITE 550MB/510MB)
Western Digital BLACK 1TB 7200 RPM 64MB CACHE SATA 6.0Gb/s
24X DUAL LAYER DVD-RW W/LIGHTSCRIBE
nVidia GeForce GTX680 4GB DDR5 2DVI/HDMI PCI-EXP Video Card
REALTEK 8-CHANNEL DIGITAL SOUND ONBOARD REALTEK
10/100/1000 Gigabit Network Card (onboard)
NZXT Phantom 410 CA-PH410-B1 White Steel / Plastic ATX Mid Tower Computer Case DELUXE COOLING PACKAGE
CORSAIR 750 WATT HIGH PERFORMANCE SLI/CROSSFIRE POWER SUPPLY
Microsoft Windows 7 Home Premium 64-bit 3
