Need FAST HELP! << Motherboard which one!?
gamersbureau
43
Ok, I'm in need in rapid help, I have 2 options:
ASUS P8Z68-V PRO/GEN3, LGA 1155, Intel
OR
Gigabyte Z77X-D3H Intel Z77 (Socket 1155) DDR3
OR
GIGABYTE GA-Z77-DS3H Intel Z77 (Socket 1155)
Which one should I go for??
I have:
Intel i5 2500k
Radeon 6870 (I wish to crossfire soon)
2x4 gb of Ram
I'm looking to add Minimum 3 fans on my system
Have you taken a look at ASRock Z77 Extreme4 ??
From the ones you suggest I recommend Z77 chipset simply beacuse is newer
And the only difference I can find between them is that D3H support Crossfire and SLI and the DS3H only crossfire, so if you are not planning on switching to Nvidia go for DS3H
The bottom one can't do x8/x8. If you want to use 2x video cards, I would avoid that one.
However, I would highly suggest you not crossfire. Just ebay the current card and buy 1x a bigger one.
It is matter of personal preference just pick the one you like best. The first two listed are decent but i am partial to Asus and Asrock.So i would suggest that Asus board. doesn't mean it is better though just what i would pick 😉
