need help about overclocking pentium d 915
Overkiller
4
Hello everyone, I run a Pentium D 915 with stock cooling on a Gigabyte GA-945P-S3 and 1024 DDR2 667; now my question is that: Could I overclock the processor without any volt mods up to 3Ghz (and without a different cooling) and would it make a difference in performance?
Thank you :)
Thank you :)
Yes, you could do that, no problem. You will barely notice any difference with that small of an overclock. GL :)
PS. Have you had that system running yet, as the Gigabyte GA-945P-S3 doesn't support the P915D yet, according to the CPU support list from Gigabyte?
http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ClassValue=Motherboard&ProductID=2324&ProductName=GA-945P-S3
Thank you :)
yes, I have that system for about 3 months.......thats really wierd ; thanks
