need help building a budget pc
Ahmad Komari
18
here are the specs http://pcpartpicker.com/p/dVWmpg
its mainly for 720p gaming
this is my 1st time .
1- i need to make sure that everything is good
2-do you think i can get something better with the same price (i can go above my budget )
3-air cooling or water ?
4-can i oc with this mobo and its safe?
5- what is the difference between gpu models like (960 msi) (960 evga)
and thank you
Ryarwood99
904
I'm not the best at telling good builds but will try to help... First split up the RAM to a 2×4GB kit so you can dual channel http://acer.custhelp.com/app/answers/detail/a_id/1664/~/what-is-dual-channel-memory%3F
I am the last person to ask about OC as I don't do it
Difference between brands just means who manufactured the card but they both used the same chipset, you can however buy pre-OC GPU just check the clock speeds and amount of RAM
Jeff Baffalo
830
A little more $$$ than your current build
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($229.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler ($19.45 @ OutletPC)
Motherboard: ASRock Z97 PRO3 ATX LGA1150 Motherboard ($80.98 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($49.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($48.75 @ OutletPC)
Video Card: PowerColor Radeon R9 290 4GB PCS+ Video Card ($238.98 @ Newegg)
Case: Enermax OSTROG ATX Mid Tower Case ($33.75 @ Newegg)
Power Supply: Antec HCG M 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($59.99 @ Newegg)
Optical Drive: Samsung SH-224DB/RSBS DVD/CD Writer ($12.99 @ Newegg)
Operating System: Microsoft Windows 8.1 OEM (64-bit) ($87.98 @ OutletPC)
Total: $862.85
Generated by PCPartPicker 2015-06-08 23:05 EDT-0400
