NEED HELP BUILDING MY GAMING RIG
DJ YUSIE
13
HI GUYS
im new here so dont xly know how it works i sold my q9550 rig now i want to build me a sandybridge rig
so here it goes :
Case: nzxt-phantom choice between three colours(black white & red) http://www.guru3d.com/article/nzxt-phantom-review/
OR
hafx 932 http://www.coolermaster.com/produc [...] ct_id=6632
PSU: 600w isonic 18a x4 rails
Mobo: MSI P67A-C43 R1000
CPU: Intel Core i5-2500K Sandy Bridge
CPU Fan: :stock im going to upgrade the cooler in the future to the corsair h60
Video Card: gtx 470 R1500
RAM: 4 x Kingston Hyper-X KHX1333C7D3/2G 2GB DDR3 1333MHz R680
OR
2 x 2gb ocz reaper 2000mhz R500
HDD : 15000 rpm cheetah drive with a iCYDOCK MB123iK-1B
A few things you should tell us
- Are you going to overclock
- What resolution are you going to be gaming at
- What is your budget
- What sites do you prefer
- What parts do you not need
thanx for the reply uhm let me see buget ....there isnt much of that im a very poor guy 🙁 anyway
- Are you going to overclock - yes in the future but not much only a little thats when i get my corsair cooler and thats going to take sum time to build up the buget again
- What resolution are you going to be gaming at - im planning on buying a 32"samsung full hd tv as a monitor so ima try and take it to the max
- What is your budget - i live in south africa and my buget is about R7000
- What sites do you prefer - ?
- What parts do you not need - if you talking about the mobo then the stuff im going to need is
6gb sata ports
3gb sata ports
usb 3.0
single pci exp slot or dual but im not planning to run dual gfx anytime soon and atleast 2 pci slots
ddr3 ram slots must take atleast up to 2000mhz memory speed incase im buying that 2 2gb ocz reaper sticks R500 instead of the 4 x 2gb kingston sticks R680
its going to be a bonous if i get onboard gfx just incase my gfx card blows
6gb sata ports
3gb sata ports
usb 3.0
Do you know how much that is in USD?
oops sorry here you go
$1 = R6.67
https://ikonicit.co.za/index.php?dispatch=checkout.cart
buget is R6500 now car broke and i had to fix it :fou: so what i xly wna know now is the choice that i have now 2 x 2gb ocz reaper 2000mhz cl9 ram R500
or
4 x 2gb kingston hyper x 1333mhz cl7 ram R680
index.php
ok so i orded the goodies yesterday and now the waiting part comes and now i came across another problem i need to decide between 2 cases the nzxt phantom and the haf 932 but im not in a hurry cos i got an old case that i can use for the moment
Well, out of those two, I would personally go with the Phantom, because I am big on looks of cases. I like how nice and smooth it is. But, for around the same price of the 932, you can get the Antec Lanboy Air, (right now). Which is a good deal, because it is usually about 200 I believe.
I think that the Phantom is cooler, because the front opens, and there are so many customizing possibilities with it. Also, it is a bit taller, and has room in the top for stuff (more customizations, fan controllers, etc.)
THANK U GUYS
so it looks like im going to buy the phantom case now just to decide the colour whitelooks cute but im a smoker so that white will def turn into a cream colour so thats a no go red black black with green stripe uhm....
i just hope im not gna have problems with the door like u had i think i should put it in a metal cage then it wont happen me ripping the door off lol
