Need help building pc
AnimeTech
26
So I wanted to build a nice gaming pc that would last me a few years. I currently have an older PC that doesn't run many games anymore. And my monitor isn't much of anything either. I wanted to build a pc around the gigabyte 1080 ti aorus extreme edition, and possibly a Gigabyte - GA-Z270X-Gaming 9 EATX LGA1151 Motherboard, but as I've never really built a pc before, and I don't exactly know what the best parts would be, I don't really know what to use. I want to keep the pc itself under 3000$, and monitor can be any price. Other accessories like keyboards, mouses, headphones, etc that you think should be added to the build, doesn't have to count towards the price of the build itself. Any help is welcome!!! - Update : I forgot to mention that I would like to use a be quiet case, but it doesn't have to be. I just want a quiet build.
Oh I don't think so. SLI Bridges are just connectors - all of them work with all the Graphics cards. No need for brand-specific ones - but make sure they're good quality, and also make sure they're long enough to actually reach both GPUs. You can do that by making sure that their length is at least as much as the gap between the two PCI-E slots on the motherboard - otherwise just get a long flexible one.
What if I want to eventually use the new asus ultrawide when it comes out, the 200hz one, will I be fine with the ryzen?
How is this build? https://pcpartpicker.com/list/ZdqbQV
I can't be sure about this, but I think it would be safe to say no. 4.1 GHz for running 4K at 200Hz? Probably not. But I'm not sure even the 7700K would be enough for that. You might have to go with an X CPU then, because that's some hefty CPU load right there. Of course I'm saying all of this only through my speculation. According ti an article I just read, they say a 6850K would be better suited for 1080 Ti SLI. Honestly, I doubt Ryzen will cut it for high refresh rate 4K gaming. I'd consider an Intel chip in that case. But are you sure you wanna go with that monitor? Seems kinda unreasonably priced to me...
Again, end decision is on you, but my recommendation would be Intel's upcoming lineup for 4K@200 Hz. They seem more reasonably priced, and will be more suited for such a heavy task. But then, you'd be still paying quite a premium for that kind of processing power.
Sorry, I completely missed the build. Um, looks good, but a single 1080 Ti won't be enough. 1440p@165 Hz is more demanding, actually, than 4K@60 Hz. So, a 1080 Ti SLI is what you'd need for that. Again, since its high refresh rate, Ryzen won't cut it - get the 7700K instead, it'll be more suited for that. I'll have to go now, but I'm sure someone else would be available to help you out - Tom's hardware has enough helpful people :). Gotta get my beauty sleep, beauty or not xD.
Mmmmm, I was trying to keep the build under 3k, while also keeping everything I wanted in it. So anyone who can help, what would be a good build for a 1440p monitor 165 hz, or should i go down to 144 hz? This is my build now.
https://pcpartpicker.com/list/DGyVQV
Not sure if I need to change anything or not, but any help would be appreciated..
If you have a budget to meet, then buying a 165Hz monitor isn't going to be exactly what one would call "budget friendly". I would definitely suggest a 144Hz monitor instead.
Would the build I made work with a 144hz monitor? Or even just a single graphics card?
You'll need at least a single 1080 minimum if you want to get 144Hz.Keep in mind that these monitors are minimum $599. A 1080TI should get decent frame rates, but I wouldn't get anything less than that.
I have up to 3000 to spend on a pc, and I can get any monitor, no matter the price. But I'd like it to be 1440p monitor. In my current build I'm working on, there's this:
https://pcpartpicker.com/list/MvfFnn
You think that'll be enough for 144hz?
Monitor is being bought by someone else other then me, the 3k is for the build itself, bought by me.
Okay, so you're going over-budget. Well, there's quite a lot you could downgrade there without losing too much performance. My recommendation would be to get a slightly cheaper Asus motherboard, or get a smaller HDD. You could try lowering the RAM to 16 GB, since that's all you need for gaming and streaming. 32 GB is more important for servers and such. Really, you can easily reduce the cost here.
https://pcpartpicker.com/list/ZrZ9Z8
I just changed the motherboard here, and you can see the build is now in your budget. You can go a bit higher with the motherboard, this was just to show you.
https://pcpartpicker.com/list/kKfn4C
I'd recommend this build - under your budget, and has almost all the features still. I'm not even sure what is better in the Maximus IX Hero. Anyways, this build should be good. Will let you run at 1440p at 165 Hz no issues.
This really should be your choice here. Unless there's yet another plot twist to come... 😀
Hope this helps. Cheers!
Incorrect. Sure servers require more RAM but to say you don't need 32GB is wrong. You can have 32GB or 64GB in a regular operating environment. You probably won't get much use out of it for gaming purposes but video and audio editing applications require way more than 16GB of RAM.
What do you need the case fans for? And why 120MM when most cases have 140MM mounts?
Of course you can have it. You can also 'have' an i7 6950X, 4-way Titan Xp, and 128 GB RAM. It's possible, but do you need it for gaming? Probably not. Yes, 32 GB is a possibility, but it's not practical, is all I'm saying.
Also, the case fans were added by AnimeTech, though even I don't think you need so many - it comes with three excellent ones, and you don't need more.
But to say that 32GB of RAM only works in a server environment is completely wrong, and if you want to give build advice, you should know this. If you want to run VR applications or anything like video, photo or audio editing you need all the RAM you can get. 16GB is the normal now, but having 32GB doesn't hurt.
I was told by someone to replace the fans from the radiator with these.. But If I dont need them then I can take them out.
Yeah kinda went over budget, wasn't expecting to do sli graphics cards. I didn't think I would need to. Was trying to keep the build at around 2500, but that didn't work xD So I had to go to my max of 3k.
They're not really necessary, and most modern cases have 140mm mounts as opposed to 120mm mounts. Check the specs of the case you're buying to make sure of the fan mounts and fan sizes before you go spending $60 - $100+ on case fans.
Alright, and do I 100% need the sli graphics to do 1440p? Making sure before I decide 100% onto a build.
So two questions. If I ran single graphics card and took out sdd until I officially get my monitor, and just keep using my 1080p 60Hz monitor, would that be alright? And also, is there anything I need to know before putting everything together? Like once I first turn it on. Is there anything I need to know?
Your SSD will not affect gaming performance - just load times. It has no effect on frame rates, so leave that in. I would just build the system as normal, you can run everything off your current monitor until you are ready to buy the new one.
Will a ryzen build do any good with 1440p gaming?
