[SOLVED] Need help but confused.
Jul 23, 2019
Hey, recently I've just figured out my administrative privileges were bugged.
I need help fixing this, and I'm also confused as I'm not as experienced.
Here is an example whenever a program I downloaded needed administrative privileges :
View: https://imgur.com/6IuQIPJ
Here is an example when I try click "Show more details."
View: https://imgur.com/meNavwV
Here is an example when I click "Ok" for "Rundll32" to give the privileges.
View: https://imgur.com/R8fNiHK
I've searched solutions.
  • I've tried "sfc /scannow in the administrative command prompt (Opened It Using Task Manager RUN command.)
  • I've tried copying a completely fine "Rundll32" file from another computer and pasting it into mine.
Neither seem to work.
Please help.
Thank you in advance.
looks like a virus, folder locations and .dll names with character soup.
what is inside that folder named 5E8C8647?
google does not recognize it or the .dll
click the one time scan, download the program and run it to scan the system.
if it detects something I would let it clean them, then backup data, wipe the drive and re-install windows.
