Need help buying a psu
Bodhisatwa
143
Hi! my cpu configuration is below-
amd athlon x2 260 3.2 ghz proceesor
4gb starlite ddr3 1333 ram
gigabyte 78lmts2p motherboard
iball lpe223-400 smps
lg l1515s tft monitor
as suggested by the other members ,i am buying the 6670 1gb ddr5 gfx card..
i need a good psu which is ok for my configurations and would allow me to make future upgrades..
i have a tight budget of rs.700...help me out..pls
Even the cheapest "no-name" PSU's (the one's we never recommend on this board) would cost you more than that (about $13.25). You would have to wait until you can afford about 26-2700 rs. to get a decent PSU that would allow for expansion. Something like this:
http://www.theitdepot.com/details-Antec+450W+Power+Supply+%28VP450P%29_C14P9671.html
Unless of course you're able to get deals that we can't. What site are you using?
Then use it for now while you save for a new one. A good PSU can last a long time (one of my setups is using a 10 year old PSU). A PSU will lose power over time but so do we all. I doubt it would be dangerous.
That's always a possibility even with new PSU's. Not that likely though. What's your alternative?
I mean what are your other options?
Not getting the GPU would be one alternative.
Buying a new, better PSU now would be another.
