[SOLVED] Need help choosing a case for my new build
eli150
255
5
18,795
Hey guys,
I recently decided to go with these specs for my new build:
cpu: Ryzen 3900x
cooler: Noctua NH D15
ram: Corsair Vengence LPX 2x16gb 3600
mobo: X570 Aorus Master
psu: Corsair HX750i
gpu: GTX 1070 ti (already have it and not looking to replace it right now).
The case i ordered is the Corsair 500D.
Is this case good enough for my new PC? should i return it and get something else?
Do you think it will run too hot or too loud?
*If you are wandring why i'm asking all these questions now is because i didn't thought about them.. I just saw the brand name, the nice look and ordered the case
...but it's kind of difficult to find the usb type c connection... any advice ?
The internal USB Type-C USB header is next to the fourth RAM slot (counting from CPU) , near the edge of the motherboard...near the motherboard diagnostic LED (CPU, VGA, BOOT DRAM).
You're good with the case you've ordered. What else are you looking for, in your chassis? In hindsight, you should ask before you pull the trigger.
The Corsair 500D is a very good case. If you like it keep it.
People will have different taste, I would have gone for something like Lian Li Lancool 2.
But that does not mean is a better case.
Thanks guys i was really worried about getting everything to fit inside the case. It arrived and i managed to get everything inside.. The cpu cooler was a bit of a challenge but i hope i'm done with it. I'm guessing I can connect every cable in the case to my motherboard but it's kind of difficult to find the usb type c connection... any advice ?
Dude thank you!!! i'll check as soon as i get home
EDIT: Thank you again i just connected everything and it works. I saw that beautiful bios screen. Now the only problem is that i cant really use my new build. The plug doesn't fit my multi socket so i had to connect it directly to my wall and then connected to the monitor to a socket on a different wall (on the other side of my room) just so i can see if everything was ok with my first build.. But i'm guessing that is a problem for some other sub-forum 😅
