Need help choosing between two builds
henriquefd
26
I'm not sure if I should get a gtx 1060 or a gtx 1070 so I have made these two builds and wonder what if the community could help me choose between them. They were made on brazilian websites. The build with the gtx 1070 is 100 dollars more expensive. I'm choosing the same monitor for both of them but would like your thoughts on the monitor as well.
1st build
-CPU: T-POWER Core i7 6700 4.0GHZ SKYLAKE
-Graphics card: PNY GEFORCE GTX 1060 6GB
-Mobo: ASUS H110M-C/BR DDR4 LGA 1151
-RAM: 8GB DDR4 2133 mhz Hyperx Fury
-HD 1TB 7200 RPM SATA 3
-Case: AEROCOOL AERO 500
-SSD KINGSTON 120GB
-PowerSupply: 600W ATX/EPS (no brand informed on the website)
2nd build
- CPU: Core i5-6600, 3.3ghz,6mb
- Mobo: Asus B150M-C/BR DDR4
- Graphics card: Zotac Geforce GTX 1070 AMP! 8GB GDDR5 256 Bit
- RAM: Corsair Vengeance LPX Preto 8GB DDR4 2133 mhz
- HD Western Digital 1000GB, 7200RPM, 64MB cache SATA 3
- Power Suply: Thermaltake 600W 80 plus, PFC
- Case: Aero 500
The monitor I am choosing is the Benq XL2720Z.
I think you should go with the 1st build, has SSD so loading times should be faster and 6700 will handle any game you throw at it, Of course GTX 1060 6 GB has lesser power than the 1070 but still 1060 will play every game you need, one more thing, if you could go with the 6700k instead it will be great for you.
