Question Need help choosing replacement PSU
ogrewar6000
Commendable
Jan 9, 2018
9
I'm not very knowledgeable about computer parts and i'm not sure what PSU i need to get. What i got confused about when looking for PSUs is all this information about Pins, connectors and rails.
Motherboard: MSI Z97 PC Mate
Graphics Card: Nvidia GeForce GTX 970
CPU: Intel Core i7-4790K
Ram: 8GB single channel DDR3
I'm using Windows 7 Ultimate 64 bit
Is there anything else i need to mention?
My current PSU (which i need to replace) is 600W, ATX12V2.31. I think it wouldn't be a bad idea to get something a little stronger since i might upgrade in a couple of years, maybe 650 watts or so? I'm just guessing here. My budget is somewhat flexible but i'd prefer around $100 USD, hopefully less but if i need to pay more to get a competent PSU then i'll do it.
I don't know which case i have.
Thanks.
DSzymborski
Polypheme
Thanks.
For your current PSU, that's just the wattage and the ATX version it conforms to (or at least claims to), not the model! It's possible that you actually have a quality one already.
But if not, something like this would be fine.
PCPartPicker Part List
Power Supply: Antec NeoECO Gold ZEN 700 W 80+ Gold Certified ATX Power Supply ($93.89 @ Amazon)
Total: $93.89
Generated by PCPartPicker 2020-09-26 01:16 EDT-0400
Prices are higher than normal due to COVID-19 supply issues; you could sometimes find good PSUs for as little as $70 (I got my EVGA G3 750 for $73 and I have a G2 in another PC that I got for $76).
ogrewar6000
Commendable
Jan 9, 2018
9
Total: $93.89
I see, thank you. If you don't mind helping me further, what exactly should i be looking for if i want to check for alternatives? can i just copy the information from the Antec PSU you showed me into pcpartpicker's sorting? for example, the one you showed me says "EPS/ATX Connectors:2 xEPS 8-pin", so i can just copy these specs into the sorting and all of the results should theoretically fit into my computer?
The most important piece of hardware is arguably the PSU. It is the life blood of the system and not to be underestimated.
Efficiency and quality go hand in hand when choosing the right PSU for your system.
I never advocate or consider cheap bronze rated units cause of the damage a poor quality unit can do and when it fails are likely the only component in a PC that can destroy other components when they fail due to a lack of proper overvoltage/overcurrent protection.
My strong advice is: DON'T GO CHEAP
A decent and efficient PSU starts with it's rating and for me Gold certification is the start. There are cheats out there who claim false certification so choose from a reputable brand such as Seasonic,EVGA, Antec, Corsair
I also recommend to spend the little extra to get a fully modular unit for versatility and ease of cabling management and airflow.
If you want the best then I would recommend the Seasonic Focus gold certified fully modular unit.
https://www.amazon.com/Seasonic-SSR-750FX-Modular-Warranty-Compact/dp/B073GWKDVM
Also read my PSU fact below my signature.
ogrewar6000
Commendable
Jan 9, 2018
9
Thanks for the recommendations, i'll keep and see if i can find something slightly cheaper, not looking for the best, maybe just the second or third best, if i don't find anything i guess i'll just get the Seasonic.
madmatt30
Ambassador
The antec I listed IS a seasonic focus in antec casing.
The issue with psu's for the uniniated is that manufacturer branding has no relevance to what the internals of a psu actually is.
Preety much the only manufacturers/retailers that make their own branded psu's entirely are seasonic, fsp, superflower and delta.
The antec zen listed is a andyson unit (ok but not great).
Evga, corsair, antec etc use different manufacturers depending on psu model itself, they can range from low end hec/andyson/fsp/cwt models to high end seasonic /superflower/cwt platforms.
The antec I listed is pretty much THE best unit you can get for under $100 at this present time.
PSU buying can be a minefield without researching properly!
Reactions: Archaic59
DSzymborski
Polypheme
I actually meant to click the other Antec that was linked. My fault there!
The PSUs linked here are the least expensive 650W PSUs we recommend. There's a Corsair CX for a few bucks cheaper, but I absolutely would not go any lower than that.
Juular
581
124
590
21
... HEC, Sirfa, CWT, Great Wall, SAMA, Andyson, Enhance. So, like, all of them. You might not see most of them on American market but they still manufacture and sell OEM units themselves. But i agree with the rest, PSU brand has little relation to it's quality, even if it's from supposedly first party OEM like Seasonic or Super Flower. You always need to look at the performance of specific unit.
madmatt30
Ambassador
I actually forgot about the newer seasonic SIII, a seasonic branded unit that's actually made on the cheap by a fairly unknown chinese manufacturer and is not particularly good at all - very naughty move by Seasonic there!!!!
Reactions: Pickachu
