G
Guest
Guest
Archived from groups: alt.comp.hardware.pc-homebuilt,alt.comp.hardware.homebuilt,alt.video.dvd.tech (More info?)
On Sun, 02 May 2004 08:48:58 GMT, "JAD" <jdemma25@eartink.net> wrote:
>>Having both a mid to high-end sound card and *ANY* drive controller
>on the
>> PCI bus is enough to degrade performance of either or both.
>Interesting, where would I see this degradation? Would I be spending
>hours in front of a 'benchmarker' comparing or would this be something
>that is real world?
The degradation is seen when the drives and interface method "would" be
capable of exceeding 120MB/s yet can't. Then it stands to reason that
seeing it would require 1) fast enough drives 2) large continuous data
stream 3) comparison of performance on a server with (other) traffic on
PCI bus limited, contrasted with PC 32bit 33MHz PCI bus with sound, analog
capture and/or other devices in use simultaneously.
>Are we again talking of 'dropped' frames, poor
>video appearance, or rendering time increases?
I was talking primary of drive performance itself. Dropped frames and
rednering times are relative to the data rate needed. Data rate lower
than realized drive transfer rate potential wouldn't matter. Rendering
times will increase if the process is drive-bottlenecked rather than CPU
or other bottleneck... depends on what you're doing.
My partners and I have
>not come across any of this type of problem (degradations) with these
>rigs. I am always up for improvements when it comes to quality of my
>work and time spent wisely. I am not into ' look my rigs faster than
>yours' scenarios though. Also, unlike a few of my cohorts, just
>because we have been doing it this way for 15 years it 'must' be the
>'only way', is not my motto ;^)
>Thanks for the input
IF your situation is one where the job is pushing the limit of drive
throughput on PCI bus then clearly a change in drives, interface, and/or
bus applies. A "my rig is faster than yours scenario" may be something
that gets stressed too often, but in some cases that's what it does boil
down too, no magic bullet other than specing out best modern config for
the job, or use of more systems.
>on the
>that is real world?
