sidekick99 Reputable Dec 10, 2016 58 3 4,545 Dec 9, 2018 #1 So i have a jfp1 f panel cable and a 20-8 pin connector on my mobo how can i connect these? https://imgur.com/a/4ViUzyJ
Solution RARRAF Dec 9, 2018 never had led's on all the builds I have done sorry it just works or does not
RARRAF Judicious Jul 22, 2007 3,988 110 35,440 Dec 9, 2018 #2 sorry to ask but what motherboard is it ?? Upvote 0 Downvote
sidekick99 Reputable Dec 10, 2016 58 3 4,545 Dec 9, 2018 #3 ASUS B85m-gamer (micro atx) Upvote 0 Downvote
RARRAF Judicious Jul 22, 2007 3,988 110 35,440 Dec 9, 2018 #4 its not a great picture but gives you the place were it should fit in https://www.manualslib.com/manual/597835/Asus-B85m-G.html?page=27 this picture gives you more of a relation to were it is hope this helps just below the asus heat sink click on pic to zoom https://www.wootware.co.za/asus-b85m-gamer-lga1150-micro-atx-motherboard.html Upvote 0 Downvote
sidekick99 Reputable Dec 10, 2016 58 3 4,545 Dec 9, 2018 #5 It won’t fit there’s a pin on the top right of my mobo and there isn’t a hole in the connector (cable) https://imgur.com/a/I0B8UKM Upvote 0 Downvote
RARRAF Judicious Jul 22, 2007 3,988 110 35,440 Dec 9, 2018 #6 you are on the corner of the board go one in from that one or maybe two in Upvote 0 Downvote
sidekick99 Reputable Dec 10, 2016 58 3 4,545 Dec 9, 2018 #7 Yeah i did that my pc starts now but i dont have any led’s indicating it’s on Upvote 0 Downvote
RARRAF Judicious Jul 22, 2007 3,988 110 35,440 Dec 9, 2018 Solution #8 never had led's on all the builds I have done sorry it just works or does not Upvote 0 Downvote Solution
