Question Need help deciding on what to Upgrade
May 13, 2019
Recently I've decided to upgrade my modified Asus Cm-1745. I've already swapped the GPU with a gtx 1050ti, and i'm now wanting to upgrade my motherboard and cpu. My budget is currently in between 200 to 250 dollars Any help will be appreciated
current specs
motherboard: Asus F2A85-M
Gpu: GTX 1050ti
CPU: AMD A8-5500 APU
Memory: 12Gb of DDR3 1600MHz (3 sticks)
I'm assuming this is predominantly used for gaming?
Are you proposing reusing the case?
Have you replaced the PSU at this stage?
If at all possible, I'd suggest bumping the budget a little..... and replace the PSU too. Whatever was included there, has likely served it's purpose.
PCPartPicker Part List
CPU: AMD - Ryzen 5 1600 3.2 GHz 6-Core Processor ($118.40 @ OutletPC)
Motherboard: Gigabyte - B450M DS3H Micro ATX AM4 Motherboard ($67.89 @ OutletPC)
Memory: Patriot - Viper 4 8 GB (2 x 4 GB) DDR4-3000 Memory ($45.98 @ Newegg)
Power Supply: Corsair - CX (2017) 450 W 80+ Bronze Certified ATX Power Supply ($39.98 @ Amazon)
Total: $272.25
Generated by PCPartPicker 2019-05-13 18:09 EDT-0400
Would be a great bundle - although 1st Gen Ryzen, it's 6c/12t and only marginally over budget.
If you're firm on the budget, I'd look to a 2200G if I were you.
CPU: AMD - Ryzen 3 2200G 3.5 GHz Quad-Core Processor ($79.99 @ Amazon)
Total: $233.84
Generated by PCPartPicker 2019-05-13 18:10 EDT-0400
Realistically, a case upgrade should really be on the agenda at some point too... Doesn't have to break the bank.
For example:
Case: Cougar - MX330 ATX Mid Tower Case ($36.12 @ B&H)
Total: $36.12
Generated by PCPartPicker 2019-05-13 18:13 EDT-0400
