Hi all, this is the first time I post in the forum. I've been reading a lot and it seems to be really helpful!
Currently, I am deciding the components for my first PC build. I will be mainly using this PC for gaming, photo and video editing, and of course web browsing, etc.
This are the components I've been thinking of buying: (Don't get surprised by the prices, here in Argentina almost everything is twice the price 🙁 )
CPU: AMD Phenom II x4 965 BE 3.4ghz (Will try to reach 4.0ghz 😀 ) US $217
http://articulo.mercadolibre.com.ar...x4-965-am3-black-edition-34ghz-6mb-cache-_JM]
Motherboard: ASUS Crosshair IV Formula US $295
http://articulo.mercadolibre.com.ar...r-iv-formula-amd-890fxddr3usb-30sata-6gb-_JM]
RAM: 4GB of G.Skill RipJaws 1600mhz (2 sticks of 2gb each
) US $108
http://articulo.mercadolibre.com.ar...ipjaws-4gb-2-x-2-gb-1600mhz-dual-channel-_JM]
GFX Card: Sapphire Radeon HD6850 US $ 296
http://articulo.mercadolibre.com.ar...d-6850-1gb-gddr5-256bits-hdmi-14-3d-dx11-_JM]
Case: Sentey Arvina (GS-6400) US $150
http://articulo.mercadolibre.com.ar...ina-gs-6400-e-atx-6-fans-sup-thermaltake-_JM]
PSU: Sentey Extreme Rock Power 700w Modular PSU US $ 114
http://articulo.mercadolibre.com.ar...e-erp700-sm-modular-700w-sup-thermaltake-_JM]
DVD/Blu Ray Drive: LG BluRay SATA Recorder US $ 160
http://articulo.mercadolibre.com.ar...a-blu-ray-sata-negra-lg-dvdrw-nuevas-box-_JM]
HDD: Western Digital 1TB Caviar Black SATA 3 US $122 (plus a WD 320gb Caviar Blue SATA2 I already own)
http://articulo.mercadolibre.com.ar...igital-1tb-sata3-64mb-cache-caviar-black-_JM]
Ok, so what do you guys think? Will this rig satisfy my gaming needs? Will I be able to overclock CPU/GPU (Forgot to write it but also getting a CM Hyper 212+) ?
One thing I wanted to ask you guys is to recommend me another motherboard, which should be future proof as the CH IV Formula and also a little bit cheaper.
I put all the links to the articles I am talking about (They are all in Spanish but just so you could have a reference)
So, tell me what you think, and what you think I should modify or add!
Thanks in advance!
PS: Sorry for not 100% correct grammar!
Thanks in advance!
