I’m about to purchase these DDR3 rams from different guys so I just want to know if the rams are compatible with each other before I buy them. Thanks.
Kingston Hyper X Genesis
If they came as a kit then they would of been tested to work together.Ok damn I didn’t know this.
What if they both came in pairs? I can run total of four slots with two pairs?
For what's worth though the last few systems that I added memory into worked fine but they were identical kits.
It's possible, I mean even kits with different specs could work together although speed is determined by the slowest stick. There's just no way to tell what kits would work with other kits unless you try it.Ok. That’s probably what I mean like buying two ram kits and run them together. Sorry for my explanation in my first question. So, there’s possibility for different pairs of ram together if different kits have identical specifications?
